Head gasket installation
  • loneagle
  • loneagle's Avatar Topic Author
17 Apr 2017 15:54 - 17 Apr 2017 16:24
#759446
I just finished installing my Wiseco 72mm pistons and the cylinder. Now, I'm trying to determine which side of the head gasket goes up or whether it matters or not. I don't see any lettering on the gasket and the metal rings seem to be the same width on either side. Please help. Here's a couple of pics.
'78 Kawasaki KZ 1000
'02 Harley FXDWG
'16 Harley Street Glide
Last edit: 17 Apr 2017 16:24 by loneagle.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Head gasket installation
17 Apr 2017 16:21
#759451
I go with the print facing up. Be sure it covers the front of the cam chain tunnel.
The following user(s) said Thank You: loneagle
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Apr 2017 16:22
#759452
Are you filling the O ring groove?
  • loneagle
17 Apr 2017 16:28
#759454
Thanks, Steve! Yes, I'm filling the groove with RTV and trimming with a razor blade. I want to make sure I'm doing everything correctly.
'02 Harley FXDWG
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Apr 2017 16:50
#759458
I fill it with high temp copper silicon and install it wet.
  • loneagle
18 Apr 2017 11:11
#759509
I have another question, should the sprocket rubber dampers be trimmed level with the block or will they compress enough?
'02 Harley FXDWG
  • SWest
  • SWest's Avatar
  • 10 22 2014
18 Apr 2017 12:15
#759519
I leave them be. They need to be tight.
  • missionkz
  • missionkz's Avatar
18 Apr 2017 19:11
#759553
With my one piece head gasket and 1075cc kit, I ground my damper pads a tiny bit but not as much as I've seen written to do.
I filled my o'ring groove with high temp Ultra Black and sprayed both sides of my head gasket with a thin coat of Copper Coat sealer. Assembled it all tacky.
So far, and thousand of miles later, no unusual cam or chain noise and no leaks!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
The following user(s) said Thank You: GPz550D1, loneagle
  • loneagle
18 Apr 2017 19:17 - 18 Apr 2017 19:18
#759555
Thanks for the help!... Got the cylinder head installed and everything torqued to spec. Now it's time to degree the cams....
'02 Harley FXDWG
Last edit: 18 Apr 2017 19:18 by loneagle.
