Baffling Baffle.
  • Johnbug
  • Johnbug's Avatar Topic Author
Baffling Baffle.
16 Apr 2017 21:50
#759358
Im not sure if this is considered professionally done, but I see spot welds...
Has anyone seen this type of baffle before? Is this something that could cause issues? Should I replace the baffle? Should I simply pound out the bents in the baffle and fix some small holes?
Any ideas?
This was taken off a 78' 650B2A. 4-1 Pipes.
Proud Confused Owner Of A KZ650B2A
  • JMKZHI
  • JMKZHI's Avatar
Re: Baffling Baffle.
17 Apr 2017 05:07 - 17 Apr 2017 05:39
#759375
google search mac baffles. apparently, the tube ends are flattened & welded together. new are available. other aftermarket baffles might fit.
Last edit: 17 Apr 2017 05:39 by JMKZHI.
The following user(s) said Thank You: GPz550D1, Johnbug
