late valve timing will end in lean condition?
  • shamal
  • shamal's Avatar Topic Author
13 Apr 2017 10:56
#759109
i don't whant to mix up the discussion with my other'' late timing- shifting relationship'', so i started another 3D:
i searched on the net but i did not get an answer: it's possible that a 1 tooth retarded inlet cam can result in a lean condition, wither plugs tips, exaclty as a lean carburetor setting do?
1983 kz 550 h
  • TexasKZ
  • TexasKZ's Avatar
Re: late valve timing will end in lean condition?
15 Apr 2017 07:36
#759227
I don't see how that could happen.
I suppose if the intake cam was wildly advanced, some exhaust gasses could be blown back into the intake tract, causing a lean (diluted) mixture. For that to happen, I bet there would also be some piston to valve contact going on.
