kz750 four head/block machining
  • jason8887
  • jason8887's Avatar Topic Author
11 Apr 2017 06:13
#758958
My 1980 kz750 4 cylinder is leaking a little bit of oil between the head and block. I am sure this is due to a scratch that was put into one or the other during a previous rebuild. Does anyone know how much material I can safely remove from the head and/or the block?
  • Nessism
  • Nessism's Avatar
Re: kz750 four head/block machining
11 Apr 2017 07:22 - 11 Apr 2017 07:23
#758965
You can't take much off the head before hitting the valve seats. The cylinder is less restrictive.
Sounds like you are getting ahead of yourself. Pull the engine down and check everything out and then decide what needs to be done.
One thing I do know is that aftermarket gaskets range in quality from passable to pure crap. Spending a little extra and getting proper OEM Kawasaki gaskets is the way to go if you value oil tightness.
Last edit: 11 Apr 2017 07:23 by Nessism.
  • jason8887
11 Apr 2017 08:11
#758966
Thanks for the tips, I'll make sure to look it over before I send it out to get it cut
  • jason8887
08 May 2017 08:06
#761459
I ended up taking .003" off the head and .007" off the top of the block. The head machining cut into the valve seals a bit but it didn't go deep enough to get into the contact areas. Bike's back together and runs great
  • undiablo
  • undiablo's Avatar
08 May 2017 12:42
#761487
Awesome, thanks for sharing the results!
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
