Missing stock exhaust compenser
  • shamal
  • shamal's Avatar Topic Author
09 Apr 2017 04:47
#758819
On my zx900a the PO removed the center exhaust compenser running under the engine and that its supposed to connect the two left headers with the other 2 on the right.
What this can cause ? Loss in performance? Dull sound at idle as i already have?
1983 kz 550 h
Re: Missing stock exhaust compenser
09 Apr 2017 08:41 - 09 Apr 2017 08:46
#758830
Removing the exhaust equalizer between the two exhaust pairs would be expected to slightly reduce efficiency of the exhaust system with stock mufflers.
Good Fortune! :)
Last edit: 09 Apr 2017 08:46 by Patton.
The following user(s) said Thank You: GPz550D1, shamal
09 Apr 2017 08:57
#758832
Take a look through the following thread. newOld_kz1000 performed a rather nice repair/replacement of the crossover pipe for minimal dollars. Ed
www.kzrider.com/forum/2-engine/432214-81...-nipple-broke#432570
  • shamal
09 Apr 2017 11:19
#758842
Patton wrote: Removing the exhaust equalizer between the two exhaust pairs would be expected to slightly reduce efficiency of the exhaust system with stock mufflers.
Good Fortune! :)
Yes i have stock mufflers. Is this missing equalizer that make my bike sound a bit DDUDDUDDU sound at idle?
1983 kz 550 h
09 Apr 2017 12:23
#758850
Might be exhaust leaks incident to removal of equalizer components.
Good Fortune! :)
