Engine Temp Gauge Sensor
- tomsbadkz
04 Apr 2017 10:51
On my KZ1327 project, I want to put a temp gauge on it. Its a big block and we know they get warm. What I'm asking is, My ZN1100 cylinder head prepped by LarryC was threaded in the rear boss of the head at 10mm. I'm looking at Trail Tech TTO gauges. Would i get more accurate reading with their spark plug sensor or at the original sensor at the lower back side of the head?
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- undiablo
Re: Engine Temp Gauge Sensor
04 Apr 2017 13:22
I would put it at rear boss. But that´s me. If Kaw took temperature from that point for its EFI, good enough for me.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- tomsbadkz
04 Apr 2017 17:40
thanks for your imput. tom
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
