Torque for Clutch Cover - KZ550 shaft/F1 Spectre
- Hexadecimus
03 Apr 2017 17:04
How tight should the clutch cover bolts be? I can't find torque specs in any of the PDF manuals I found for this bike.
Thanks
Thanks
Re: Torque for Clutch Cover - KZ550 shaft/F1 Spectre
03 Apr 2017 17:55 - 03 Apr 2017 17:58
Snug. If you insist on a number use the basic torque chart based on bolt size that's in the service manual. Just know that a little loose won't hurt anything and it avoids stripped threads.
EDIT: the chart says 52-78 in-lbs for a 6mm screw. I'd go to the lower end of that range.
Last edit: 03 Apr 2017 17:58 by Nessism.
The following user(s) said Thank You: loudhvx, Hexadecimus
- loudhvx
04 Apr 2017 06:56
They didn't usually give torque specs for machine screws (JIS cross-head). I guess it was expected you would be using a screwdriver and would just use reasonable force.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Hexadecimus
04 Apr 2017 08:08
Thanks for the generic specs. Should be enough. And they're 5mm allen heads btw.
- KZB2 650
04 Apr 2017 08:37
Was wondering that a while back (as I have allens too) and went with 60 inch lbs that's in the manual. Did that for the carb holder bolts and just go good and snug on the side covers. Can see where you could get into trouble going too tight with the allens but I've found out the 60 inch lb reading is about what I stop at by hand and have never had a problem.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- JMKZHI
09 Mar 2018 05:50 - 09 Mar 2018 05:50...
The clutch cover bolts should be 6mm. The parts diagrams usually have the bolt sizes.
Last edit: 09 Mar 2018 05:50 by JMKZHI.
- loudhvx
15 Mar 2018 08:42
Typical 6mm allen bolts will require a 5mm allen wrench.
(Like how typical 1/4" bolts will require a 7/16" wrench.)
1981 KZ550 D1 gpz.
Other links.
Other links.
- JMKZHI
16 Mar 2018 07:12 - 18 Mar 2018 05:38
Yes, but he didn't specify if he meant the bolt size or the wrench size. In this case it probably won't matter, but if a guy could get into trouble when installing a something like a valve cover if he doesn't know the difference between the two.
Last edit: 18 Mar 2018 05:38 by JMKZHI.
