Damper Plugs?
- N0WH3R3
Damper Plugs?
30 Mar 2017 23:53
Hello again after a looooong break!
So I'm in the middle of putting my engine back together ('80 KZ750E)
and noticed that 1 of the damper plugs (part # 92066-1016) is missing.
They are cheap enough to replace and I'm going to order some but
what purpose do these serve exactly and is it bad idea to run without them?
1980 KZ750 LTD (under construction)
Re: Damper Plugs?
31 Mar 2017 05:36 - 31 Mar 2017 05:40
The dampeners supposedly help prevent a "ringing" sound induced in the fins by a running engine.
Doesn't hurt anything to run without the dampeners.
Am guessing these were more effective on large-fin two stroke engines.
Last edit: 31 Mar 2017 05:40 by Patton.
The following user(s) said Thank You: GPz550D1, N0WH3R3
- KZB2 650
Re: Damper Plugs?
31 Mar 2017 06:33
Seems like it would cool slightly better if they were left out but left em alone.... wonder if any racers out there ever remove theirs.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- Kidkawie
- I bleed premix
Re: Damper Plugs?
31 Mar 2017 10:56
You can cut slices of rubber hose too.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
The following user(s) said Thank You: N0WH3R3
- N0WH3R3
Re: Damper Plugs?
31 Mar 2017 23:41Thanks! I think I'm gonna run it without them.Patton wrote: The dampeners supposedly help prevent a "ringing" sound induced in the fins by a running engine.
