gpz900 engine doesn't sound right... with video
  • 2005jetta
  • 2005jetta's Avatar Topic Author
28 Mar 2017 19:47
#757987
Hey everyone. My roommate picked up a bike last weekend and we just got it running. it runs great but it makes a loud mechanical noise. I'm not sure what it is but I think it might be the timing chain. I am hoping that one of you might be able to tell me what I am hearing. I have included a video with this post. Please tell me what you think. Thank you in advance.
    20170325_1..._s01.avi
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: gpz900 engine doesn't sound right... with video
28 Mar 2017 20:05
#757991
Sounds like carbs out of sync.
  • 2005jetta
04 Apr 2017 15:44
#758499
Thanks for the quick reply and sorry about the delayed response. We are attempting to sync the carburetors right now however I'm running into a problem. I understand that there is for vacuum lines that run to the sync gauge however the port on the number two carburetor is vacuum for the gas tank. Is that where I hook up the line for the number two carburetor? I was thinking that that would kill vacuum to the gas tank and fuel would not flow while syncing the carbs. I was able to hook up 3 to the gauges but they are jumping around erratically when making adjustments. There is only 3 adjustment screws while syncing, correct? They are the screws between each set of carbs? Any ideas? Thank you in advance./center]
  • TheForumTroll
  • TheForumTroll's Avatar
06 Apr 2017 13:26
#758638
When you pull the fuel vacuum line just set the petcock on PRIME and it will let fuel through.
-[ KZ700-A1 '84 ]-
