hey guys new to this forum. I just picked up a 1979 kz750 twin, i will plan to turn into a brat sometime in the near future. when i first got it it needed a new gasket for the crank case which i changed out and done an oil change at the same time. However my bike still has a leak. It is dripping on to exhaust and causing smoke. There is oil on an oil pan screw but it could be coming from the gasket that i had replaced. it not a big amount so its hard to notice. Ill try and post some pics up in a bit.
