I broke number 3 cam bearing holder!!
- peter1958
Re: I have a problem!!
18 Mar 2017 16:40
www.kzzone.com/
- VTEC
21 Mar 2017 18:20 - 21 Mar 2017 18:24
Technically, because the caps are cast with the head, the correct repair is a new head. But if you install a used #3 cap, and the cam spins freely with oil clearance is in specs, It most likely would be fine. I've done it on a Honda Civic engine.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
Last edit: 21 Mar 2017 18:24 by VTEC.
Re: I broke number 3 cam bearing holder!!
21 Mar 2017 23:55
If i look at cam shafts they are looking like brand new "HOT" cams.
- rrsmsw9999
22 Mar 2017 07:03
I would replace it with a used salvage one. That is going to vibrate and heat cycle over time. I think it will run the risk of loosening. Good news is it will be clanging long before it comes free. The machining will be tolerant with the cap, more tolerant than if it loosens and comes free. I suppose too you could locktite the bolts and reduce torque appropriately. Alternately, a good MIG/TIG guy could get that in a jig and spot weld the crack. Some heat deformity in the bracket shouldn't be too excessive. Good Luck. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- slmjim+Z1BEBE
22 Mar 2017 07:07Agreed. Conditionally. That being, it would be in the back of our minds, bugging us to no end.peter1958 wrote: You can just run it like that.
The cap bolts carry the vertical loads imposed by the valve springs. Lateral thrust is essentially nil, being limited almost entirely by the camchain.
We see loose cam caps at Mid Ohio often. Maybe should begin stocking up on them...?
Good info in Peter1958's link too.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Kidkawie
- I bleed premix
22 Mar 2017 08:24
What's the clearance spec? Find a coupla used caps and plastigauge it.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
The following user(s) said Thank You: missionkz
- zed1015
22 Mar 2017 08:42
It will be just fine as is.
Can't really move anywhere.
No's 1 and 3 caps control camshaft end float though so you may want to fit locating dowels to the two bolts that don't have them for extra security or have the bridge spot Tigged with it in situ but have seen loads running like this with no issues.
Fitting a rogue cap from another head will put you deeper in the shit with additional fitting problems to address as they can be off in every plane which will cause even more damage if you don't know what you are doing.
The following user(s) said Thank You: GPz550D1, SWest
30 Jul 2017 20:46
PM sent... I have bearing caps if you still need them
- jenkrider
01 Aug 2017 16:25
Off topic but I really dig that gloss black engine paint, I hope it holds up for ya. What kind is it?
76' KZ900
00' KLR650
82' XV920 Virago
74' Ironhead Sportster
00' KLR650
82' XV920 Virago
