- Thank you received: 1
I broke number 3 cam bearing holder!!
- dberg
18 Mar 2017 13:30 - 19 Mar 2017 21:53 #757002
by dberg
I broke number 3 cam bearing holder!! was created by dberg
Hey everybody,
Hope somebody can help me, I broke number 3 cam bearing holder. How does a guy go about getting a replacement.
Any help would be great!!
Thanks
Dan
Thanks
Dan
Last edit: 19 Mar 2017 21:53 by KZQ.
- Thank you received: 2063
18 Mar 2017 13:38 #757005
by Scirocco
Replied by Scirocco on topic I have a problem!!
Sorry no replacement!!!!!
The cam bearing holders are machined together (mounted ) with the cylinder head.
Take some pics for a better repair solution
The following user(s) said Thank You: TwoCam, dberg, GPz550D1
- dberg
18 Mar 2017 13:45 #757006
by dberg
Replied by dberg on topic I have a problem!!
- Thank you received: 2823
18 Mar 2017 13:49 #757008
by Nessism
Replied by Nessism on topic I have a problem!!
I'm not super familiar with the big KZ engines but on many similar engines you can exchange caps without issue. The caps are line-bored with the head but the manufacturing was quite accurate such that interchanging caps rarely causes issues.
Regarding that crack, is it possible to simply align the crack and bolt the cap back on the engine? The bolts will hold the cap in place regardless of the crack.
The following user(s) said Thank You: dberg, GPz550D1
- dberg
18 Mar 2017 14:01 #757011
by dberg
Ok, I will just bolt it back on and see what happens.
Thanks guys
Thanks guys
18 Mar 2017 14:08 #757012
by Scirocco
Some of the advanced members here in the forum use screw clamps to tension the cam shafts down to prevent such a damage to the cam caps.
Sorry didnĀ“t found the picture yet.
- Thank you received: 2829
18 Mar 2017 14:09 #757013
by 650ed
Replied by 650ed on topic I have a problem!!
Just curious - how did you break it? Ed
18 Mar 2017 14:11 - 18 Mar 2017 14:14 #757014
by Scirocco
He broke it at the lateral guides of the cam shaft. I suspect that the Cam shaft was not lateral centered
Last edit: 18 Mar 2017 14:14 by Scirocco.
- dberg
18 Mar 2017 15:07 #757022
by dberg
The way I broke it, I was getting in a hurry and did not see the bearing had slipped to the side so when I started to tighten it snapped.
- dberg
18 Mar 2017 15:11 #757023
by dberg
18 Mar 2017 15:44 #757026
by Scirocco
if the threats of the cam caps are in good condition your are on the safe site (do not over tighten them).
later ( i hope not so far ) if you must do a maintenance to your engine, you can welded the cap when the cylinder head is removed.
Good luck and enjoy your ride.
- peter1958
- Banned
- Thank you received: 198
18 Mar 2017 16:33 #757030
by peter1958
Replied by peter1958 on topic I have a problem!!
You can just run it like that.
