Oil Change Question
- Vintage3
Oil Change Question
10 Mar 2017 09:57
Hello,
I last changed my oil and filter in fall 2015. After that the bike was heat stored for last winter and last summer I only put about `150 miles on it before it went back into heated storage. Bike is a KZ1000J3. Oil in it now is a Motul semi-synthetic blend.
My question is before I change the oil in a few weeks for spring should I just unscrew the drain plug without starting it to drain it or start it to warm it up and then drain it understanding the way the bike has been stored along with the age and mileage on the oil. I know normally you would warm it up a bit and then dump the oil to make sure it all gets out but with the time that has passed between changes I am not sure.
Thanks.
Thanks.
Re: Oil Change Question
10 Mar 2017 10:44 - 10 Mar 2017 10:44
By now, for sure, the vast majority of the oil has run down into the oil pan. If you drain it cold, it may take a little longer for it all to run out, but that shouldn't matter as long as you're not in a hurry. If it was mine I wouldn't bother to warm it up. Ed
Last edit: 10 Mar 2017 10:44 by 650ed.
10 Mar 2017 15:15
I'd run the oil, not change it. Sitting in the crankcase for a year shouldn't hurt it unless you have leaking carbs/petcock.
The following user(s) said Thank You: GPz550D1, Scirocco
10 Mar 2017 15:40
If the engine was stored after a long distance ride (150 miles = no moisture in the oil) an oil change is not necessary.
