1982 KZ440-A engine noise at RPM
- FriskyNinja
04 Mar 2017 17:46
Hello everyone. I have a 1982 Kawasaki 440 LTD that I picked up for $250 from a friend. The friend owned it for 6 years and rode it for the first two years he owned it, then the battery died and he stored it. I purchased the bike, cleaned it up, new battery, rebuilt the carbs, cleaned the tank, and prettied it up a bit expecting the bike to be able to start and go with minimal work. However, now that it's running it's knocking like crazy and has a slight chain noise at the rear of the engine (I assume the final drive chain). Here is a link to a private YouTube clip of the engine running for 14 seconds with revving to around 3500 rpm. I would love some opinions of what it is and what I should look for if I end up tearing it down, or if I should just find a cheap engine to replace it with. I appreciate any help that can be given.
Attachment not found
- Nebr_Rex
Re: 1982 KZ440-A engine noise at RPM
04 Mar 2017 19:34
Sounds like a rod. Check your valve clearance and cam chain tensioner first to eliminate those possibilities.
You could swap another engine. But that would be taking a chance on another bad engine. I would rebuild
what I had and then I know what I have. What pipe do you install on the bike?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
04 Mar 2017 19:54
BTW, that chain noise is not the final drive chain, your bike is belt drive. Could be cam chain, The crankshaft has a chain drive balancer and the starter is chain drive. They will make quite a clatter if the carbs and valves are not adjusted properly.
- Nebr_Rex
04 Mar 2017 20:33
The primary is chain driven.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- FriskyNinja
05 Mar 2017 15:07Nebr_Rex wrote: Sounds like a rod. Check your valve clearance and cam chain tensioner first to eliminate those possibilities.
The pipes were on it when I bought it, I rattled them black.
The tensioner is automatic on this bike and the chain seems taught and the valves are in spec.
I'm thinking I may rebuild it so like you said I know what's in it.
- Nebr_Rex
05 Mar 2017 17:42
The stock exhaust would have a muffler on both sides.
If you need some info on what can be done to the 440
look at the link in my signature.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Kitten Tooth
08 Mar 2017 09:54
I had a starter clutch come loose on my KZ1000. I'm sure it was similar to the one on your bike (even though yours is a chain driven starter). When that thing comes loose off the big magnetic flywheel on the end of the crank, it can make some ugly noises. Its more of a rattle than a knock though. You can get a pretty good look at the rods if you remove the oil pan. (saves the top end gaskets if its not a con-rod issue. alittle Side-to-side play is normal but in-out play is bad.
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
