ENGINE REMOVAL & DISASSEMBLY Tools
- Fox
02 Mar 2017 20:34
Hello,
what are the needed special tools to remove and disassembly the engine properly?
For example the "Clutch Removal Tool" that i hear about...
Thank you
Thank you
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Re: ENGINE REMOVAL & DISASSEMBLY Tools
02 Mar 2017 21:39
Hello Fox
This is the clutch removal tool
and tools also needed
Do you have a FSM or need one?
Michael
Michael
The following user(s) said Thank You: GPz550D1, Fox
- Fox
02 Mar 2017 23:05
Hello,
FSM ?
Thank you for the all tools list
What i mean is the very necessary tools that i will need to disassembly the engine.
For most of them we can replace by hand made tools...
I have to replace the shift forks...
Regards
FSM ?
Regards
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
02 Mar 2017 23:36
- Fox
03 Mar 2017 00:17
Thank you. I will receive the 78 ltd manuel in 1 week
Do i ave to disassembly all the engine to replace the shift forks? Or can i do it from the bottom?
actually i plain to do that :
but not very hot...
but not very hot...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
03 Mar 2017 01:01
Separate top from bottom case and get out all gears and shafts,no need to remove head, cylinder, pistons and crankshaft.
Read here to:
kzrider.com/kunena/11-projects/604902-19...inter-rebuild#755658
Read here to:
- Fox
03 Mar 2017 01:42
Yes i see now.
Thank you very much
Thank you very much
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- rrsmsw9999
03 Mar 2017 06:42
Once you get to the tranny you nay see more than shoft forks that need work. If you are that close in and haven't had a top end refresh, now's the time while its out. It is also going to be a PIA to move a full motor around on the ground or bench without a stand. Good luck. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- Fox
04 Mar 2017 22:50
Hello,
Ok. The shift rod was not anymore in is axe.
A small part was going down...
Now I just have to check the shift forks to be sure.
- I have to pull off the shift rod.
Do i have to open and disassembly the clutch side to pull it off Or can i just take it by the transmission side ?
- I need a new transmission cover screws set. Those ones are too old.
Do you have a good address?
Thank you
Thank you
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Fox
05 Mar 2017 09:35
No... seems i need to remove the clutch to pull off the shift rod... I'm true?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Fox
05 Mar 2017 11:24
So :
The shift rod clip was going down. Then the shift rod was free (not in it's axe).
I will disassemble the clutch to pull off the shift rod from the clutch side end.
Then i will be abble to check the 2 shift forks
I'm i true?
I'm i true?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Fox
07 Mar 2017 11:33
No eBay APP ID and/or Cert ID defined in Kunena configurationMy version seems to have a cerclip on the clutch side. Impossible to remove the shift rod form the tranny side...
Do someone have the same ?
I need to go to the clutch end but i don't have the clutch tool. Afraid to use an impact driver...
Will this tool fit the kz1000 ltd 1978 ? :
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
