Buttons vs circlips
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Buttons vs circlips
03 Mar 2017 16:50
#755709
What do you do just slide them into pistons and nothing holds them in right?
the Teflon butons pop into the wrist pin ID as a push fit. Another advantage is they can be re-used.
I used them recently, the 0.8mm wire size for my Yoshimura pistons were unobtainable.
The following user(s) said Thank You: dberg
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
03 Mar 2017 17:02
#755712
dberg wrote:
I don't know if this worked but these are the buttons
Stiff Upper Lip Bud
Those are the best pistons made, ( MTC )
I have them in a high boost turbo motor , buttons and all.
Mine are flogged with more power and heat than you will ever see in your motor.
Make sure you get the rings on right and you will be good to go !!
DaveB) B) B) B)
  • dberg
  • dberg's Avatar Topic Author
03 Mar 2017 17:29
#755717
Thanks to all of you guys!!!
Made me feel a lot better about the buttons
Dan
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
03 Mar 2017 17:29
#755718
Street Fighter LTD wrote:
Stiff Upper Lip Bud
DaveB) B) B) B)
Totally agree I used other make of pistons, although I have no complaints about them the MTC are just that little bit better(after 100K klms)
