third gear bump to second
- Fox
23 Feb 2017 02:41
Hello all,
I 'm starting to work on my kz1000 ltd b2 1978 to resolve a problem :
When i ride in third gear it bump alone to second gear when i accelerate.
It bump from third gear to neutral when i decelerate...
What can be the problem? I would really appreciate some good keywords to start working on it
Regards
Fox
Regards
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Re: third gear bump to second
23 Feb 2017 05:29
If this happens in third gear only, it could be a bent shift fork that is not allowing the gears to fully engage. If this has happened very many times, the engagement dogs may be badly rounded off as well. The only way to know for sure is to break open the crankcase and carefully measure and insect the transmission and related parts.
The following user(s) said Thank You: GPz550D1, PLUMMEN, Fox
- rrsmsw9999
24 Feb 2017 11:56
You have a bent or broken shift fork(s). You will need to split cases to fix. most of the parts are out there. i would stop shifting it until you inspect the tranny. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
The following user(s) said Thank You: GPz550D1, Fox
- Tyrell Corp
25 Feb 2017 17:08
Before you split the cases just try requisitioning the gear lever on it's spline, sometimes they don't nudge the gear shift quite enough ... a long shot but worth at try. Also if it has been down the road the external selector mechanism could be bent..that is an easy fix.
I'm tall with big feet so have to set all my bikes up just for me....others find my bikes uncomfortable to ride. Add a pair of size 12 hobnails steel toecap and this gear lever set up becomes more important otherwise more missed gears and awkward neutral selection.
- Fox
01 Mar 2017 21:17 - 01 Mar 2017 21:17
Ok thank you
I know what i have to do now.... wow...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Last edit: 01 Mar 2017 21:17 by Fox.
- Fox
02 Mar 2017 20:40
Hello,
Kz1000 ltd 78 seems to have T4 wrote on shift forks (from my searches)
Can i use btw T2 or T8 that look similar or they won't fit?
Thank you
Thank you
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Fox
05 Mar 2017 14:06
When i ride in third gear bump alone to second gear when i accelerate.
Witch one forks must be in cause?
Thank you
Thank you
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
05 Mar 2017 14:34
IMO, you should carefully measure the relevant parts of the forks, the grooves the forks ride in and the drum. The specifications are in the fsm. If one of the forks is bent, it could cause excessive wear elsewhere. Doing it right the first time will save you time and money later.
