Advice on getting her to breathe (76 KZ900 LTD)
- JDRAKE4200
20 Jan 2017 08:29
All,
I need some help. I am having some work done and am not sure what to do, so I am going to throw rocks at the hornets nest. I need to know what kind of air cleaner to run. Here is the work being done. 1976 kZ900 LTD, back cut transmission, welded crank, 1075 kit @ 10.5:1 compression, .400 lift cams with short duration, Intake boot port, exhaust ports opened up a bit as well, Vance & Hines sidewinder pipe. I have a set of 29MM SB’s that I am going to run. I have a stock airbox, with K&N air filter. I also have a modified airbox that the hole on the intake side of the air cleaner has been made bigger to flow more air that the K&N will fit into. My question is should I run one of my air boxes, or should I get K&N pods. Please let me know your thoughts. Want to try and figure out which way to go as if I am going to run pods, want to get them now. And if you guys vote pods, should I get the K&N, or is there another cheaper option that work as well? Lemme know guys. Thanks!!!!!
Keep the shiny side up!!!!
1976 KZ900 LTD
2004 Sportster 1200 Custom
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
Re: Advice on getting her to breathe (76 KZ900 LTD)
20 Jan 2017 09:48
You may as well go for the pods. I'm not a fan of pods generally speaking, but with a modded bike such as yours pods seem like a natural.
APE pods are reputed to be nice and they are quite a bit cheaper than K&N's. I'd stay clear of Emgo's and the like.
20 Jan 2017 15:44
I had pods on 29 s with a very similar engine package. I cant remember jetting as it has been many years , but I sorted it out and the bike ran great idle to full WOT and at mid range while cruising.
- Dr. Gamma
20 Jan 2017 15:54
Dump the stock air box for sure!!!!
1986 RG500G 2 stroke terror.
- JDRAKE4200
25 Jan 2017 11:24
Thank you....any ideas on the jetting??
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
- Kapahulu
25 Jan 2017 12:58
i run 20 pilots and 120 mains. You might start off higher on the mains, say 130 then work your way down if needed.
2strokeworld.com
2strokeworld.com
25 Jan 2017 14:23
If you do remove the airbox - DON'T HURT IT and don't lose any of the related parts. They sell for quite a price on eBay. Ed
- spdygon
27 Jan 2017 11:45
If you think you'll be riding in the rain ....then I suggest using the modified air box with the K&N filter.
You won't be able to tell the Power difference ...
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
