Stuck Clutch
  • jerry a smith
  • jerry a smith's Avatar Topic Author
Stuck Clutch
03 Jan 2017 11:48
#751306
I've put a rebuilt '78 kz 1000 motor in my '75 Z1 , so far unstarted. ( In the process of building a roller starter). The rear wheel spins freely, but after i've put it in gear and shift it back into neutral there is so much drag it takes a lot of force to break it free and then it'll turn freely again . The clutch plates were new. Got me baffled.
Jerry.
  • SweetwoodSUP
  • SweetwoodSUP's Avatar
Re: Stuck Clutch
03 Jan 2017 19:54
#751334
That isn't a clutch problem. It is a tranny problem. Sounds like a shaft bearing. It might go away under power and a little use might free it up.
'79 LTD 1000
'84 Ninja 900 (Sold, What was I thinking!)
'81 CSR 305 (sold)
'69 BMW R75 (Sold)
  • jerry a smith
Re: Stuck Clutch
04 Jan 2017 05:44
#751344
Thanks. I've had the clutch apart and it looks and works fine. What you say makes sense. I'll let you know how it works out.
Jerry.
