Anyone blast with fine Walnut Shell media???
  • z1kzonly
  • z1kzonly's Avatar Topic Author
03 Jan 2017 10:49
#751298
Anyone ever use fine crushed "walnut shell" media for abrasive blasting?
Before I buy 25# of it, I'd like to know the finish it would leave on aluminum?
I have always used fine micron glass beads. My favorite!
But I was at the cheap chinese tool store and was reading it polishes metal and rocks put in tumblers? Less aggressive on materials?
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Anyone blast with fine Walnut Shell media???
03 Jan 2017 11:04
#751301
z1kzonly wrote: Anyone ever use fine crushed "walnut shell" media for abrasive blasting?
It is used by bullet reloaders to clean brass cartridges to like new condition.
Should be fine
  • Nessism
  • Nessism's Avatar
03 Jan 2017 11:15
#751302
Walnut shell is one of the least aggressive blast medias available. The real question is whether or not it's sufficiently abrasive enough to do the job you are intending? Walnut shells are good for something like cleaning carbon off the top of a piston and/or the combustion chamber and ports of a cylinder head. If you have some corroded parts though I tend to doubt walnut shells will be aggressive enough to remove the damage.
  • z1kzonly
03 Jan 2017 11:28
#751304
Yes, Thanks Guys, I am re-doing a Mark II Smog cylinder head and stock barrel & 1015 pistons.
Yes I will use aluminum oxide first to cut down the black paint first, then I always finished with glass.
Just might try the walnut shells, I always wondered if I could blast plastic covers with walnut to get that paint out of the seams and crevices of parts that have been re-painted. I have had paint jobs that had almost a 1/16" of material built up. And God awful Dupont "Imron" enamel from the 80's That paint was has hard as Powdercoat!
  • ayeckley
  • ayeckley's Avatar
04 Jan 2017 08:00
#751361
It's what we used to clean pistons when rebuilding Lycoming pistons engines for light aircraft. If it's good enough for the FAA bureaucracy it's good enough for me. We also used some sort of chemical stripper that is probably illegal nowadays too. It reportedly would dissolve Volkswagen engine cases. Trichloroethane perhaps?
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
  • zukdave
  • zukdave's Avatar
05 Jan 2017 16:28
#751496
I know a few car guys that use it to blast sheet metal parts to strip paint
they say it doesn't build as much heat.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
