After market ring confusion.
Re: After market ring confusion.
01 Jan 2017 16:52
There have been discussions about a certain brand of aftermarket piston and ring sets. I would measure every component carefully.
- chuck hahn
04 Jan 2017 15:28
I sanded the pistons with some 1500 and set the rings as noted in the service manual. Placed the rings in the bores and all the end gaps were OK according to the book. Bike runs great without any noise when on the needles but it does still chug little at idle.
One thing I did notice is that the oil light starts to flicker at around 1,000 RMS as i adjusted the big idle knob down.
I was told years ago that rings will spin around the pistons when its running. Is this true or folk lore on the rigs working themselves around the pistons when running???
04 Jan 2017 16:23
It's true. I'd check the oil pressure now.
- chuck hahn
04 Jan 2017 16:31 - 04 Jan 2017 16:40
How do I do that?? I imagine via where the sender unit screws in under the timing plate??? What kind of adapters and gauges do I need???
Last edit: 04 Jan 2017 16:40 by chuck hahn.
04 Jan 2017 18:03
What bike is this?
- chuck hahn
Last edit: 04 Jan 2017 18:11 by chuck hahn.
04 Jan 2017 18:18
You can get a adapter that matches the threads on the sensor and a regular pressure gauge. Do you have a manual?
- chuck hahn
04 Jan 2017 18:20
Yes...a hard copy and the PDF online file is downloded
04 Jan 2017 18:24
It should tell you what the pressure is. I think it's a high pressure system so that's important.
steve
steve
- chuck hahn
04 Jan 2017 18:40
Havent found it as of yet. The sections covering the oil pump or the pressure relief valve doesnt mention an expected oil PSI far as I can find.
04 Jan 2017 18:59 - 04 Jan 2017 18:59
I thought it was 60-80 cold. Here's a link.
www.kzrider.com/forum/2-engine/416211-wh...l=component&type=raw
Last edit: 04 Jan 2017 18:59 by SWest.
- chuck hahn
28 Jan 2017 15:08
She seems to be doing ok. Took a 20 mile ride today without issues. Got a situation with the turn signal lights though. See my post inn the electrical section for details.
