1980 KZ750 LTD ring orientation
  • braddlesnake
  • braddlesnake's Avatar Topic Author
28 Dec 2016 11:14
#750824
hello,
i found some new old stock OEM rings but they don't come with any ring orientation diagrams, my manual is pretty useless on this front as well, I have a square and a beveled ring, which goes in the top and bottom and is the bevel up or down?
thanks for the help.
brad
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1980 KZ750 LTD ring orientation
28 Dec 2016 11:41 - 28 Dec 2016 11:44
#750825
The markings are on top. The cutouts are on the bottom. This may help.
Last edit: 28 Dec 2016 11:44 by SWest.
The following user(s) said Thank You: braddlesnake
  • martin_csr
  • martin_csr's Avatar
28 Dec 2016 12:51
#750829
Manual. What manual are you using? Is the bike a 750-4? There's a good pdf available on the 750Turbo site.
28 Dec 2016 13:02 - 28 Dec 2016 13:03
#750830
braddlesnake wrote: hello,
brad
I HIGHLY recommend that you buy a Kawasaki Service Manual rather than whatever you currently are using. Ed
Last edit: 28 Dec 2016 13:03 by 650ed.
  • braddlesnake
02 Jan 2017 20:40
#751239
Good tip Ed this Haynes manual seems to be missing a lot of vital info.
Thanks for the scans.
Brad
  • braddlesnake
02 Jan 2017 20:41
#751240
It is a 750 4, I'm using the Haynes manual. Not too helpful.
  • braddlesnake
03 Jan 2017 08:42
#751277
thanks for the tip, any chance you could post the link to the PDF? can't seem to find it.
Brad
  • martin_csr
03 Jan 2017 09:07
#751282
Manual. 1980-84 KZ750-4. KZ700. 1983-85 ZX750. 750turbo.com --- Index .
The pdf manual link is near the bottom of the list. good pdf scans.
Wiring diagrams. mbsween. bike-night. KZ750L3 . Scroll down & click "The Bible" link.
the site has wiring diagrams & a manual that isn't scanned as good as the one on the Turbo site.
Note: some of the wiring diagrams are mislabeled in the links: the 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4.
