Oil pan bolt
  • BIGRob850
  • BIGRob850's Avatar Topic Author
Oil pan bolt
02 Dec 2016 06:31
#749283
Have a 82 kz750 m1 csr twin. I'm replacing oil pan gasket and have no clue what the oil pan bolt torque specs are. Don't want to brake a bolt or a have a new leaky gasket. Any help would be appreciated.
1982 kawasaki kz750m1 csr twin
  • Nessism
  • Nessism's Avatar
Re: Oil pan bolt
02 Dec 2016 06:35 - 02 Dec 2016 06:39
#749284
Don't you have a factory Kawasaki service manual? The specs for such things are contained there in.
Below is from my 750/4 manual and may help...
Edit: firewall where I work is blocking image attachment. You are on your own to find the info...
Last edit: 02 Dec 2016 06:39 by Nessism.
  • mopguy
  • mopguy's Avatar
Re: Oil pan bolt
02 Dec 2016 06:53 - 02 Dec 2016 06:55
#749288
This site was previously posted by Martin CSR
www.750turbo.com/manuals/Base%20Manual%20An%20Introduction.pdf
Last edit: 02 Dec 2016 06:55 by mopguy.
  • JR
  • JR's Avatar
Re: Oil pan bolt
02 Dec 2016 07:14 - 02 Dec 2016 07:45
#749289
for the 79 750 twin the manual says 0.9 - 1.1 kg-m or 78 - 95 inch - lb
your 82 likely has the same size bolts so torque should be the same as above.
Last edit: 02 Dec 2016 07:45 by JR.
  • BIGRob850
Re: Oil pan bolt
02 Dec 2016 10:09 - 02 Dec 2016 10:10
#749300
@ Nessism
I do not. Just got this bike the other day on trade for a little tool box.
Last edit: 02 Dec 2016 10:10 by BIGRob850.
  • BIGRob850
Re: Oil pan bolt
02 Dec 2016 10:11
#749301
Appreciate it JR
  • KZB2 650
  • KZB2 650's Avatar
Re: Oil pan bolt
02 Dec 2016 12:04 - 02 Dec 2016 12:05
#749305
Mine call for 61 to 78 inch lbs so I went at it slow 10 or so at a time till I hit 65 let it sit a day then went a touch more with a 3 inch long wrench to feel em and they all felt good and snug..... over kill but it made me feel sure of it. Bought a after market gasket first (in 2012 and they sent me two by mistake)...... offered to send it back but they told me to keep it.......then decided to order a original from Partzilla this time and liked the quality of it better.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 02 Dec 2016 12:05 by KZB2 650.
  • BIGRob850
Re: Oil pan bolt
02 Dec 2016 20:07
#749326
@ Kzb2 650
Appreciate it
