Starter rebuild
  • MadeupofWires
  • MadeupofWires's Avatar Topic Author
Starter rebuild
27 Nov 2016 11:38
#749043
I'm currently in the process of trying to rebuild my started. I have hit a bump in the road quite early in the process. The screws that hold the sidecover in place will not budge. Anytime I try to remove them the heads want to strip. I've sprayed them with some liquid wrench. Has anyone had this issue and gotten the screws out?
  • stokes
  • stokes's Avatar
Re: Starter rebuild
27 Nov 2016 11:48
#749044
Are you using a JIS screwdriver or a plain philips head?These jap bikes need the JIS driver
1980 KZ1000B Ltd
  • MadeupofWires
Re: Starter rebuild
27 Nov 2016 11:55
#749045
Plain old phillips. Havent heard of the JIS. I'll check it out.
  • McZed
  • McZed's Avatar
Re: Starter rebuild
27 Nov 2016 11:56
#749046
If you take your Philips screwdriver and grind a little of the point then it will then fit the JIS screws.
  • KZB2 650
  • KZB2 650's Avatar
Re: Starter rebuild
27 Nov 2016 12:44
#749048
You might to think about a impact wrench too before the heads are tore up too bad...... I switched over to allen heads a long time ago with a trace of anti seize to save this head ache.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • TexasKZ
  • TexasKZ's Avatar
Re: Starter rebuild
27 Nov 2016 15:23
#749058
Are you sure the starter needs to be rebuilt ? They are amazingly sturdy. Usually, thr starter clutch goes first.
JIS info here---
www.kzrider.com/forum/10-new-members/603...ums-and-bikes#735668
  • 750 R1
  • 750 R1's Avatar
Re: Starter rebuild
27 Nov 2016 15:32
#749059
MadeupofWires wrote: Plain old phillips. Havent heard of the JIS. I'll check it out.
The reason a large percentage of screws are all chewed out is due to the use of Phillips head screwdrivers, these are NOT Phillips head screws, as mentioned above, they are JIS (Japanese Industrial Standard), JIS screwdrivers are the absolute best tool to remove these screws, nothing is better or more efficient.... ;)
These are the ones I use and highly recommend, This is an Australian site, the drivers with the silver handles are actually Impact drivers.
Google Vessel USA, there are plenty of people selling these in the USA... ;)
rhinotools.com.au/product/jis-vessel-screwdriver-set/
