KZ 400 Rpm question.
- eulis
26 Nov 2016 10:52 - 26 Nov 2016 13:23
I just recently bought a 75 kz400 and in 5th gear at 45 mph I'm running 4500 rpm,at 65 mph it's 6500 and so on.is there a way to change my gear ratio to bring my rpm's down at high speeds
Last edit: 26 Nov 2016 13:23 by KZQ. Reason: make topic searchable.
Re: Rpm
26 Nov 2016 11:07
Installing a front sprocket with one more tooth makes a nice difference for freeway riding. You have to check if there is room on the engine first and also make sure the chain is long enough. Upping the gearing any more than this and the bike will feel like a dog at low rpm's. The 400's are designed to spin so let them.
- eulis
- KZQ
- Administrator
Re: Rpm
26 Nov 2016 13:21Every machine has a 'Cruising' speed where it and you, the rider, agree things are good. For some bikes 65 MPH is a stretch. I suspect that might be the case on a 400 at 65 MPH. Still if you can bear it:eulis wrote: So it won't hurt it to run at 6500 for periods of time
As Nessism said "Let it spin."
Keep the oil clean and pay attention to the maintenance schedule.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Nerdy
Re: Rpm
26 Nov 2016 13:56Nessism wrote: Installing a front sprocket with one more tooth makes a nice difference for freeway riding. You have to check if there is room on the engine first and also make sure the chain is long enough. Upping the gearing any more than this and the bike will feel like a dog at low rpm's. The 400's are designed to spin so let them.
If there's no room for a larger front sprocket, dropping 2-3 teeth on the rear sprocket will give the same results.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Re: Rpm
26 Nov 2016 14:02Nerdy wrote:Nessism wrote: Installing a front sprocket with one more tooth makes a nice difference for freeway riding. You have to check if there is room on the engine first and also make sure the chain is long enough. Upping the gearing any more than this and the bike will feel like a dog at low rpm's. The 400's are designed to spin so let them.
Yes, this can be done also. One tooth in the front is equal to about 3 in the back since the stock ratio is pretty close to 3:1
- Nebr_Rex
Re: Rpm
26 Nov 2016 17:29
Stock tooth count is 15 front and 45 rear.
Or 45/15 which equals 3.00/1.
You will have a hard time finding anything other than a 15 front.
I have a 33,38 and 41 rears. They are out there you just have to look.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- KZQ
- Administrator
Re: Rpm
26 Nov 2016 18:43
Playing around with drive ratios can be informative and all the comments you've gotten here are golden. There is one thing I know about Ma Kaw, and that's that she generally knows best. My bet is that after you've lowered the final drive ratio, you'll get that easier cruising at 65 MPH but you'll loose driveability around town. At least that was my experience when I tried the same thing on my KZ900.
Just Saying.
Bill
Just Saying.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- eulis
Re: KZ 400 Rpm question.
26 Nov 2016 19:43
Thank you guys for the advise,I may just leave it as is.bike runs and looks too good to be messing with it
- KZQ
- Administrator
26 Nov 2016 20:00eulis wrote: Thank you guys for the advise,I may just leave it as is.bike runs and looks too good to be messing with it
Good Decision!
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Z1Driver
- love the smell of triple smoke
27 Nov 2016 20:00
Could be normal RPM range for a 400. Many years ago I let my buddy who had a 400 borrow my 74 900. He came back with a ticket because he said he watched the TAC more than the Speedo. At 60 MPH my 900 Tac shows 4K or there abouts.
Blue 1975 Z1B
Red 2009 Concours 14
- ThatGPzGuy
28 Nov 2016 04:38
Other KZ400 owners might weigh-in here but I recall the last time I was on the freeway with my '76 I was closer to 5K RPMs at 65. I need to get it out so maybe I'll wind it up at little and report back.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
