Clutch Cable Disengaged
- fatcat70
14 Nov 2016 12:43
I pulled off the left side sprocket cover I think it is to take a look at the starter motor on my KZ550 C-1. When I put the cover back on I think something got messed up with the clutch cable. The tension in the clutch cable feels pretty normal, but I can't get the push button to start the engine (the starter motor is receiving voltage) and I can't shift into first gear either. This leads me to believe that the clutch isn't completing the circuit for ignition and also isn't engaging the clutch since I cant shift.
Any ideas?
Thanks, Joel
Any ideas?
Thanks, Joel
1980 kz550 LTD
Re: Clutch Cable Disengaged
14 Nov 2016 13:05
The clutch interlock switch is in the hand lever on my 750. I only have to pull the lever in part way to be able to engage the starter motor.
- bluezbike
15 Nov 2016 15:27
Make sure the clutch cable end is situated properly in the cover (ask me how I know) and redo the proper tension...what happened on my bike is that the PO's mechanic had installed a clutch cable but the cable end did not seat properly and therefore when it popped in one fine day I lost all ability to control the clutch......puckered right up I can tell you..... :ohmy:
......also while replacing the cover you may have inadvertently parted/severed a connection to the starter, all those wires run behind the cover....at least they do in my 1000.
79 KZ 1000 LTD
