Tuning the ears. Exhaust sounds
- Jekyll86
11 Nov 2016 20:27
Hello Gents!
This is my first motorcycle build and I have been playing around with a couple variables to see what happens. I have noticed an exhaust sound that is accentuated when the baffles are removed from my exhaust. What Im referring to specifically occurs when chopping the throttle after revving to moderate/high Rpm. If I let off on the throttle easy and do not let it snap back, it does not occur. It's easily observed in the video not he first and third revs. I have a couple of hunches, but want to see if any of you have an idea as to what it may be.
It isn't really something that bothers me but I wonder if it is a symptom of an underlying issue.
The bike and potentially relevant info:
-Kz700 with 810 kit
-Pods (carbs jetted and tuned well)
-Stock header pipes (4 into 2)
-short high flow mufflers (baffles taken out for video as this accentuates the sound and can be heard easily in the video).
Attachment IMG_4225.MOV.mov not found
-Kz700 with 810 kit
1984 KZ700A1 Franken-saki 810 kit
1976 KZ400 broken-saki
1981 KZ750B
2018 z900rs
1981 KZ750B
2018 z900rs
- Jekyll86
Re: Tuning the ears. Exhaust sounds
11 Nov 2016 20:41
I also realize thats not the best video in the world. I can get another shot of it tomorrow when the neighbors won't hate me quite as much.
also, I have been attaching the file and clicking the insert button but the videos aren't showing on the page without the link. any suggestions?
1981 KZ750B
2018 z900rs
1981 KZ750B
2018 z900rs
- loudhvx
12 Nov 2016 07:22
I can't seem to get it to play. Maybe it's an apple format?
I would get a youtube account. That makes it universal and will show up in posts as a clickable video image.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- JOE MKII
12 Nov 2016 07:54
I listened to the video, My uneducated non-expert opinion of the sound is that with a short unbaffled exhaust like you have that is the sound you are going to get.
I bet the sound would change based on carb/filter set up, CV carbs vas slide carbs, baffle cone shape and of course baffle material in the exhaust.
Straight pipe Harleys have a very similar sound when the throttle is closed abruptly.
I believe its called "Oppositional Defiance Disorder"
