650 Crankshaft
  • The Milkman
  • The Milkman's Avatar Topic Author
650 Crankshaft
05 Nov 2016 13:46
#747351
Hi guys it's been a while since I've on here, quite a change.
Does anyone know the main journal size of a 78 650 engine?
Thanks,
Les
  • Nessism
  • Nessism's Avatar
Re: 650 Crankshaft
05 Nov 2016 14:56
#747356
Here is a link to the factory Kawasaki service manual. A very useful piece of literature for people that own bikes as old as ours. You can find the crank pin size inside too.... www.zedrider.co.uk/service--owners-manuals.html
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: 650 Crankshaft
05 Nov 2016 18:32 - 05 Nov 2016 18:34
#747380
Hey Les, good to see you.
The crankshaft journals' outside diameter standard is 1.3773~1.3780 in. (34.984~35.00 mm).
Service limit is 1.3768 in. (34.97 mm).
If the diameter is less than the service limit, the crankshaft must be replaced.
More to come.....
[IMG
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 05 Nov 2016 18:34 by rstnick.
  • The Milkman
Re: 650 Crankshaft
06 Nov 2016 10:47
#747418
Thank you for the replies, Guys.
Les
