4 into 1 Mac header on a KZ550
- carwash
04 Nov 2016 19:29 - 04 Nov 2016 19:32
No eBay APP ID and/or Cert ID defined in Kunena configurationI got a Mac 4 into 1 header awhile ago. It's just the header, no muffler or connecting pipe. My bike currently has stock carbs, airbox, exhaust and it is running great.
If I put this header on (with a muffler yet to be determined, but something with a baffle), what's the good and what's the bad?
How much tuning will the bike need if any? Any performance increases?
Was thinking about adding a Cone Engineering reverse cone shorty muffler.
Does this seem like a crazy good deal? Was thinking of making an offer, just to get the muffler.
1980 KZ550A
1980 CB750F
1980 CB750F
Last edit: 04 Nov 2016 19:32 by carwash.
Re: 4 into 1 Mac header on a KZ550
05 Nov 2016 04:19
If you leave the stock airbox and filter in place and only change the exhaust then you may not have drastic jetting problems.
That Kerker is a crazy good deal. You may want to grab that thing for the muffler. A local shop should be able to bend you up a mid pipe piece.
- loudhvx
06 Nov 2016 06:54 - 06 Nov 2016 06:55
Kerker is always my first choice for a muffler. It'll be a little leaner, but you can probably use stock jetting with it.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 06 Nov 2016 06:55 by loudhvx.
