Cam chain length
  • loneagle
  • loneagle's Avatar Topic Author
Cam chain length
03 Nov 2016 07:42
#747100
I received my replacement cam chain and noticed when comparing them that the new one is shorter by one link. I wouldn't think a chain would stretch this much. I'm kind of concerned here and need some advice.
Attachment camchain.jpg not found
This is the chain I ordered www.z1enterprises.com/product/KL12-8099 I have a special tool to rivet the link back together.
'78 Kawasaki KZ 1000
'02 Harley FXDWG
'16 Harley Street Glide
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Cam chain length
03 Nov 2016 07:46
#747101
How many links and what bike is it? My old chain stretched about 1/4" compared to the new one.
The following user(s) said Thank You: loneagle
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
03 Nov 2016 07:51
#747102
Are the # of links the same as indicated on the box?
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Nessism
  • Nessism's Avatar
03 Nov 2016 07:53
#747104
It seems you purchased the wrong chain. Removing links is okay to get the proper length but I wouldn't attempt to lengthen.
  • loneagle
03 Nov 2016 07:58
#747106
78 Kz1000 I'll have to count the links and compare what it says on the box. Thanks for the replies!
'02 Harley FXDWG
  • zed1015
  • zed1015's Avatar
03 Nov 2016 08:08 - 03 Nov 2016 08:24
#747108
loneagle wrote: 78 Kz1000 I'll have to count the links and compare what it says on the box. Thanks for the replies!
You need a 122 link chain for your 78 1000 ( Which would have been Part number EK 219 H )
The one you have bought is 124 links which fits the later (square cam cover) MK2/ST1000 .
Simply remove 2 pins to get the correct pin count and length ( it's the same chain type and pitch)
Last edit: 03 Nov 2016 08:24 by zed1015.
  • KZB2 650
  • KZB2 650's Avatar
03 Nov 2016 08:14
#747109
Are you figuring in the link you are going to rivet in ?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • loneagle
03 Nov 2016 11:06
#747121
Ok, I got it all figured out. I had a brain fart and was looking at the wrong chain this morning. :S Yep, I did the count and got 122 pins. Thanks for the help!
'02 Harley FXDWG
