What brand aftermarket gaskets are any good?
  • 1959xlch
  • 1959xlch's Avatar Topic Author
30 Oct 2016 09:31
#746549
Hello, I have a 1981 KZ440LTD that I feel needs to be re-ringed. It keeps fouling out the left cylinder spark plug, has only about 60 psi of compression. I can oil the cylinder, get the compression back up to about 120-125 and then it goes back down after running it. I filled the cylinder with compressed air, and the air leaks from the crankcase, not the intake or exhaust. Sooo, what aftermarket gaskets do you guys use? Looks like everyone does not like the Athena sets. Also any good ring recommendation? The bike sat for many years as shown by the bike only having 5K miles, I will also need some valve seals. It would be silly not to replace them while the head is off. :) Thanks for any information. Ride safe.
Attachment Resize.jpg not found
1981 KZ440LTD
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: What brand aftermarket gaskets are any good?
30 Oct 2016 10:38
#746561
Dont know the availability for your 440 but Cometic are top of the line gaskets for the 1000s
  • Nessism
  • Nessism's Avatar
30 Oct 2016 12:28
#746570
OEM Kawasaki gaskets and seals are the best in most cases. One possible exception is that there are some nice viton valve stem seals on the market.
  • 750 R1
  • 750 R1's Avatar
30 Oct 2016 15:11
#746604
Street Fighter LTD wrote: Dont know the availability for your 440 but Cometic are top of the line gaskets for the 1000s
Agreed, Cometic MLS head gaskets are the best by far, make sure the heads surface is glass flat.....
  • 1959xlch
02 Nov 2016 16:08
#747002
Excellent, I will look into Cometic gaskets. Does anyone have a good source for them?
1981 KZ440LTD
