Starter not engaging
  • old squid
  • old squid's Avatar Topic Author
17 Oct 2016 14:45 - 17 Oct 2016 14:47
#745474
I have a 1981 Kawasaki KZ440. The brushes went bad in my starter I rebuilt the starter and tested it with a battery charger. I reinstalled it and it just spins. It does not engage.
Last edit: 17 Oct 2016 14:47 by old squid.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Starter not engaging
17 Oct 2016 15:48
#745483
Need to rebuild the clutch.
  • stokes
  • stokes's Avatar
17 Oct 2016 17:56
#745493
I had a similar problem,starter was just spinning.I pulled the starter and it was fine,pulled off the left side cover and found my rotor bolt came loose and the gear that connected to the starter gear was just spinning.Tightened up the bolt and its been fine since.
1980 KZ1000B Ltd
