Missing Filter Bypass Assembly
- johnnymoff
16 Oct 2016 08:50
When changing oil for the first time on this bike 77 A1 KZ1000, I found the filter bypass assembly missing.
I have part a, of course, but no: B, C, or D.
Is the oil getting filtered at all?
Attachment BypassValveAssembly.png not found
Engine: 77 KZ1000 A1
Frame: 78 KZ1000 B2
Carb Type: VM 26 with accelerator pump.
Needle clip: 3rd (middle) position
Pod air filters
Main Jet 132.5
Idle Jet 20
Clip position on needle 3rd (middle)
Exhaust 4 into 1 Vance and Hines
PO says 1170 kit installed.
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
- johnnymoff
Re: Missing Filter Bypass Assembly
16 Oct 2016 09:03
I am also missing the Fence in this picture. And, I have a bolt on the cover that is not shown in my manual - I have indicated where this bolt is with the orange circle in the pic. I am using a newer manual for J, K and M models. What does this bolt do - kind of looks like a simple drain hole.
Do I need a Fence?
Do I need a Fence?
Attachment OilFilterandFence.png not found
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
- zed1015
16 Oct 2016 10:06 - 16 Oct 2016 10:13
Nothing missing from your filter bolt.
Later 998cc J motor filter arrangement is different.
Your early kickstart equipped motor has the bypass valve in the case a drain bolt on the cover and doesn't use the metal shield.
You should get the correct manual for the 903cc/1015cc motors before doing any further maintenance .
Last edit: 16 Oct 2016 10:13 by zed1015.
The following user(s) said Thank You: johnnymoff
- missionkz
16 Oct 2016 10:32
I have the same bike and as mentioned, you are trying to use the wrong manual...
look for a 76-77 manual, part Number 99931-540-01
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
