Dyna s trouble
- MassKZ
Dyna s trouble
14 Oct 2016 14:36
I installed a dyna S on my KZ650. The bike runs like a champ at WOT and during acceleration , idles a bit ruff and spits and pops at low and cruising speeds. I was going to static time it, but when I put the light on it, it just stays on no matter the plate position and when I rotate the engine. Any help would be greatly appreciated.
Re: Dyna s trouble
14 Oct 2016 15:10
Did you set it at full advance per instructions? Spark advance free?
The following user(s) said Thank You: MassKZ
- MassKZ
Re: Dyna s trouble
14 Oct 2016 15:23
I did set it at full advance. I'm going to double check to make sure the spark advance is moving freely.
- Tyrell Corp
Re: Dyna s trouble
16 Oct 2016 18:22
make sure the advancer can rotate freely and snaps back sharply, check it running with a strobe.
Re: Dyna s trouble
16 Oct 2016 18:43
- MassKZ
Re: Dyna s trouble
17 Oct 2016 17:00
Thanks for the help everyone. I have it dialed in almost perfect, but it's still a little lumpy and it spits slightly at cruising speed. I think the carb boots are the issue.
Re: Dyna s trouble
17 Oct 2016 18:35
Carbs synced?
- MassKZ
Re: Dyna s trouble
18 Oct 2016 12:11Yeah. I synced them a while back. I'll double check them when I have them off, but I noticed a cracked in one of the boots.swest wrote: Carbs synced?
Re: Dyna s trouble
18 Oct 2016 13:18
They need to be vacuum synced.
