Oil leak
- askaraboz
Oil leak
08 Sep 2016 12:31
I've developed this oil leak on my Kawasaki KZ1000P that seems to be getting worse. It's coming from under that cracked rubber boot. Could someone tell me how to fix this? Thank you.
Re: Oil leak
08 Sep 2016 12:45
The oil pressure switch is under that cover. Check the appropriate parts fishe for your bike and look it up. Attached is a link to the '84 fishe but your bike may be different.
www.partzilla.com/parts/search/Kawasaki/...CRANKCASE/parts.html
- missionkz
Re: Oil leak
08 Sep 2016 13:27Agreed, and a simple fix.Nessism wrote: The oil pressure switch is under that cover. Check the appropriate parts fishe for your bike and look it up. Attached is a link to the '84 fishe but your bike may be different.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Re: Oil leak
08 Sep 2016 13:49 - 08 Sep 2016 13:50
Take the O ring out and get a new one at any AP store. I'd replace the other two as well.
Last edit: 08 Sep 2016 13:50 by SWest.
