KZ400 removing clutch cover/shifter return spring
  • de Courcy
  • de Courcy's Avatar Topic Author
07 Sep 2016 21:41 - 07 Sep 2016 22:01
#741487
Hello! I just bought a 1978 KZ400 yesterday, my first motorcycle (only has 11,000k!!) :laugh: and rode it for about 5 or 6 hours. Today it wouldn't shift properly, seemed like something happened overnight, literally.
Took it to a dealer and they said it was probably the return spring, apparently they had almost an identical bike with the same problem a few weeks ago.
I'm having trouble getting the clutch plate off, the manual is a bit unclear, also i am new to motorcycles. Looks like the timing assembly needs to come off too, but the nut turns with the crankshaft and even with the bike in gear I can't get it off. How do I remove this nut? Or do i need to disassemble the timing advancer completely?
I'd just like to take the plate off to see if it is the return or the pawl spring, but I am scratching my head on how to get it off.
Hope someone can help, and thanks in advance!
William
1978 KZ400
Last edit: 07 Sep 2016 22:01 by de Courcy. Reason: added the milage
  • de Courcy
Re: Shifter return spring & clutch cover
07 Sep 2016 21:46
#741489
I saw this topic already kzrider.com/forum/2-engine/592618-kz-400...turning?limitstart=0
There is a great video, but no info on the crankshaft nut.
1978 KZ400
  • TexasKZ
  • TexasKZ's Avatar
08 Sep 2016 04:25
#741500
What, specifically, are the symptoms?
Have you tried properly adjusting the clutch cable? There is a specific procedure.
Do you have a factory service manual? You really should have one before you start disassembling things. A Clymer manual is better than nothing, but the factory manual is more specific.
Have you checked the oil level? Do you know if it is the correct oil? It needs to meet JASO MA specifications.
  • diggerdanh
  • diggerdanh's Avatar
Re: KZ400 removing clutch cover/shifter return spring
08 Sep 2016 06:18
#741515
Good point on the correct oil. If you're not using oil specifically for wet clutch motorcycles it will have additional additives in it than can mess with the clutch - typically causing slippage.
There are two pieces at the end of the crankshaft - a larger 17mm nut that you can use to rotate the engine and a smaller bolt (14mm IIRC) that holds the 17mm nut on. Loosen the 14mm bolt and the whole assembly will come off and then you can remove the timing plate, etc. You may need to hold the 17mm nut with one wrench while turning the 14mm bolt with another (or a socket).
Ha. It's been awhile but now I remember that I ran into this issue with my first KZ400 where the bolt was in really tight. The issue is that the flat of the 17mm nut is not very wide so it is difficult to get a wrench on it and another wrench on the head of the 14mm bolt and not enough clearance to use a socket on the 14mm bolt. This is where a thin 17mm wrench or a thin-walled socket would be a blessing. I ended up getting lucky by finding a crescent wrench that was thin enough to use to hold the 17mm nut so I could get another wrench solidly on the bolt.
Best of luck to you.
08 Sep 2016 06:37
#741518
de Courcy wrote: Hello! I just bought a 1978 KZ400 yesterday, my first motorcycle (only has 11,000k!!) :laugh: and rode it for about 5 or 6 hours. Today it wouldn't shift properly, seemed like something happened overnight, literally....
Perhaps nothing's wrong.
The transmission is designed to NOT shift above neutral unless the rear wheel is rolling forward at sufficient speed.
The rear wheel can usually be rotated fast enough by hand with the bike on its centerstand in order to allow an upshift from neutral.
Actually means the countershaft must be rotating counterclockwise at sufficient speed to dislodge by centrifugal force the ball bearings that otherwise prevent the shift upward beyond neutral.
Good Fortune! :)
08 Sep 2016 07:17 - 08 Sep 2016 07:18
#741522
A KZ440 Factory Shop Manual (FSM) may be downloaded for free at www.kz400.com
Go to www.kz400.com
On the left-hand side of the page, scroll down to and click on Manual
On the right-hand side, scroll down to where you see
KZ440 Workshop Manual
A workshop manual for the following 440 models can be downloaded from here or here.
Click on the 2nd "here" (the 1st "here" produces an error message).
Takes a few moments to download the FSM.
The above paragraph is from page 179.
Good Fortune! :)
Last edit: 08 Sep 2016 07:18 by Patton.
  • de Courcy
08 Sep 2016 08:46
#741532
Thank you everyone and Thank you diggerdanh! This is the bolt i am having trouble with it's 13 and 17mm but there is no clearance. To get two sockets or wrenches on
I have a factory manual, It has the correct oil and the right amount,
The problem is the shift lever does not reset back to centre, and there is too much play with the assembly, the lever is just too loose, and yes it is attached tight to the shift shaft.
1978 KZ400
  • de Courcy
08 Sep 2016 09:20
#741537
Basically what I am wondering, Is anyone has experience taking the right side plate off, because there are three screws, see photo attached, that are almost stripped (not from me!) and I'm wondering if I need to actually take the timing assembly off just to get the plate off.
If I do, which I very well may have to, does anyone have any suggestions on how to remove those screws without completely stripping them? They are really torqued on. WD-40? Liquid Wrench?
William
1978 KZ400
  • martin_csr
  • martin_csr's Avatar
08 Sep 2016 09:31 - 08 Sep 2016 09:32
#741539
I'm not familiar with the KZ400. Is it necessary to remove the timing plate to do the shifter repair?
As for the screws, Kroil is best, but I use Liquid Wrench penetrating spray lubricant. regular wd40 isn't really a penetrant.
I would let the penetrant sit overnight & use a dremel to cut slots in the screw heads.
Last edit: 08 Sep 2016 09:32 by martin_csr.
The following user(s) said Thank You: de Courcy
  • JR
  • JR's Avatar
08 Sep 2016 09:53
#741542
It looks like it is necessary.
From page 76 of the workshop manual on the kz400 site www.kz400.com/Workshop%20manual%20bilder....maual%20p.71-81.pdf
It appears that while the shift lever is on the left the mechanism and spring are on the right behind the clutch basket and a lot of stuff needs to be removed before one can get at the spring.
There are a few members here with 400s and one may come along with good suggestions while that oenetrating oil is doing its work.
Most of those screws being JIS have been inadvertantly stripped by previous owners in the past
  • Nerdy
  • Nerdy's Avatar
08 Sep 2016 09:55
#741543
JR wrote: Most of those screws being JIS have been inadvertantly stripped by previous owners in the past
Two words: Impact. Driver. B)
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • de Courcy
08 Sep 2016 10:33 - 08 Sep 2016 12:56
#741547
GOT IT!
The shifter return spring is broken ;) now just gotta find another one..... Probably replace the pawl spring while i'm in there.
Thank you everyone!
1978 KZ400
Last edit: 08 Sep 2016 12:56 by de Courcy. Reason: edit
