Engine Compression
  • Tuxedocat
  • Tuxedocat's Avatar Topic Author
Engine Compression
03 Sep 2016 17:39
#741005
Does anybody know what the engine compression on a KZ200 should be?
  • missionkz
  • missionkz's Avatar
Re: Engine Compression
03 Sep 2016 17:49
#741006
Should be in your manual but just about all 4 stroke engines are built with minimums of around 100psi to 120psi for proper combustion.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
The following user(s) said Thank You: Tuxedocat
  • Tuxedocat
03 Sep 2016 17:56
#741007
Thank you!
  • Nessism
  • Nessism's Avatar
04 Sep 2016 18:00
#741107
Realize that to do a proper compression test...
- engine hot
-valves adjusted
-fully charged battery
-throttle held open
-engine in running condition and having recently run for 100+ miles. Don't try to do a compression test on an engine that has sat stationary for a number of years until you do a good ol Italian tune up!
