Won't go into 4th
  • JoHNY
  • JoHNY's Avatar Topic Author
Won't go into 4th
21 Aug 2016 05:44 - 21 Aug 2016 05:45
#739361
Have done nothing to the gearbox during a rebuild. Gear shift shaft is not loose and goes into 1st, 2nd and 3rd fine. Had all the linkage off and clutch cable off. Not sure what the Hell is going on, any ideas anyone?
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
Last edit: 21 Aug 2016 05:45 by JoHNY.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Won't go into 4th
21 Aug 2016 07:42
#739367
Check your shift drum pins and linkage.
  • Old Man Rock
  • Old Man Rock's Avatar
21 Aug 2016 08:57 - 21 Aug 2016 08:59
#739374
If you had removed gear shift lever off the splined shaft for the re-build....
1-2 spline off can make all the difference....
May want to re position the gear shift lever 1-2 shaft splines down (lever down direction) and test....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 21 Aug 2016 08:59 by Old Man Rock.
The following user(s) said Thank You: JoHNY
  • JoHNY
21 Aug 2016 09:38
#739379
Cheers Steve and Rock. It was the linkage, that's a relief LOL
