help with finding replacement bolt?!
  • Deshi
  • Deshi's Avatar Topic Author
08 Aug 2016 13:51
#737869
I have a bolt that snapped off i will include a picture of where it went, no idea what replacement part i need. 1982 kz750 h3
Attachment bikebolt.jpg not found
Re: help with finding replacement bolt?!
08 Aug 2016 14:35
#737874
Is the part in question the one circled in yellow in the 1st image below? If so, see the 2nd image below for the part number for it and the O-ring it uses. Both parts should still be available from any Kawasaki dealer since they were used on many newer Kawasaki models. Ed
Attachment 00003d-2-3-4-5-6-7-8-9-10-11-12-13-14-15.jpg not found
Attachment 00003a-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19-20-21-22-23-24-25-26-27-28-29-30-31-32-33-34-35-36-37-38-39-40-41-42-43-44-45-46-47-48-49-50-51-52-53-54-55-56-57.jpg not found
The following user(s) said Thank You: Deshi
  • Deshi
08 Aug 2016 14:36
#737875
thanks that was it ordering on partzilla now
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Aug 2016 15:07
#737882
Isn't that a oil pressure inspection port?
08 Aug 2016 15:17
#737884
swest wrote: Isn't that a oil pressure inspection port?
Yes. There is a Kawasaki Service Tool and adapter that can be plugged into that hole and used to measure oil pressure. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Aug 2016 15:18
#737886
I hope it's not being used to mount something. :dry:
  • Nessism
  • Nessism's Avatar
09 Aug 2016 09:22
#737988
Anyone know what size the thread is on this plug?
  • KZB2 650
  • KZB2 650's Avatar
09 Aug 2016 10:33
#738003
According to the diagram it should be 9mm and 18mm long.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • Nessism
  • Nessism's Avatar
09 Aug 2016 10:55
#738008
KZB2 650 wrote: According to the diagram it should be 9mm and 18mm long.
I think you got it backwards... :silly:
  • KZB2 650
  • KZB2 650's Avatar
09 Aug 2016 11:43
#738017
Whups should a thought on that one a little longer. ;)
1978 KZ650 b-2
