750 engine swap
- marka1373
- recovering britbike guy
750 engine swap
06 Aug 2016 20:49
Hello members,new to kz's,I own a 90 zephy 550r and a 84 gpz750..My new gpz 750 has no compression,bought from a guy who tried to freshen up the engine and failed,timing is on,but readings are nill to low.Question-im currently a low buck guy,but I would like to ride this gpz,I love the style and feel of it,slightly customized.Will any other engine drop in,thats not a gpz,and function with my 84 era electrics,see alot of 2000-2002 zr7 engines for 400. or so.i will rebuild the old one at my leisure.Any input is appreciated,looked on the net already,cant find any solid info.thanks
- missionkz
Re: 750 engine swap
06 Aug 2016 21:05 - 06 Aug 2016 21:10
The timing of "what" is on?
First thing I think if after a fresh rebuild with low compression is the builder built it with the camshaft timing way off or screwed up the shim clearances and you now have bent valves or if lucky, you have valves being held open.
If that's the case pull the head and check it out before wasting time and money on engine swaps.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 06 Aug 2016 21:10 by missionkz.
- azman857
Re: 750 engine swap
06 Aug 2016 21:19
KZ 650 or 750 (4 cylinder) can be bolted in. Get the airbox too so you can use that too. Voltage regulater for the alternator too. There are 3 types.
Re: 750 engine swap
07 Aug 2016 02:51 - 07 Aug 2016 10:25
From the the first topic linked below, the ZR7 engine swap to a 650/750 is the same as doing a GPz swap, so I would think the ZR7 & GPz engines would be the same as each other, fitment-wise.
KZR topic --- zr7 motor in KZ750 by turboguzzi
Another topic I've saved. w lots of good photos
KZR --- GPZ750/810 racer running by turboguzzi
edit: fixed the links. doh.
Last edit: 07 Aug 2016 10:25 by martin_csr.
- GPzMOD750
Re: 750 engine swap
07 Aug 2016 09:33
Your links are the same.
The first should be.
kzrider.com/forum/2-engine/602366-zr7-mo...n-kz750?limitstart=0
Re: 750 engine swap
07 Aug 2016 10:25 - 07 Aug 2016 10:26
Thanks. I just now fixed them. both were messed up. doh. the second one now begins on page 1.
Last edit: 07 Aug 2016 10:26 by martin_csr.
- zukdave
Re: 750 engine swap
07 Aug 2016 12:24 - 07 Aug 2016 12:25
An early if not all 650 motor's will not be a bolt in the mount's on the case are wider
the GPz is a rubber mount motor and has narrower case mount's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 07 Aug 2016 12:25 by zukdave.
- azman857
Re: 750 engine swap
07 Aug 2016 21:48 - 07 Aug 2016 21:50
I bolted an '82 750GPz engine into a '77 KZ650 frame. No mods needed. They changed the frame for the GPz rubbermounts.
Last edit: 07 Aug 2016 21:50 by azman857.
Re: 750 engine swap
07 Aug 2016 22:12
He's asking about a ZR7 (ZR750) engine for a ZX750 GPz.
