83 KZ1100LTD oil consumption
  • jdvorchak
  • jdvorchak's Avatar Topic Author
06 Aug 2016 18:16
#737663
What is the normal oil consumption?
I've have this kz1100 with 30k miles for a couple of months and it runs and rides great. But I'm constantly adding oil. No real leaks. Some seeping from the alternator grommet but a quarter size puddle over night. Literally 4 to 6 drops. I don't see any evidence of oil on the bottom of the bike or my left foot. Never see smoke from the exhaust and last time I checked compression it was 150 on 4. Valves adjusted 2k miles ago. About 80 percent highway and 20 percent in town.
I'm running Rotella 15w40 and a lot of in town riding. I'm having to add 4 or 5 oz of oil every couple of hundred miles to bring the level up to the middle of the window. Seems like when I check it, on center stand sitting over night, it's not registering in the window. Add enough to go 1/2 way to full up the window, usually 4 oz or so which is a guess. Not measured. But in about 2k miles I've put about a quart in.
I have the valve cover vents with just a hose between the two. The top hole in the Air box is plugged. The breather was not removed and cleaned but the hose is there and hooked to the air box.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
Re: 83 KZ1100LTD oil consumption
06 Aug 2016 18:34
#737664
If you're using about a quart every 2,000 miles you don't have a problem at all. Ed
The following user(s) said Thank You: jdvorchak
  • missionkz
  • missionkz's Avatar
06 Aug 2016 18:36
#737665
30,000 miles? Air cooled... Sounds like normal wear and tear to me.
Valve guide seals stiffening and standard oil control ring wear.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Aug 2016 19:15
#737671
Old valve guide seals. Not bad enough to tear down though.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
06 Aug 2016 19:17
#737672
Will an engine running at 5-7k rpms consume more oil than one at 4k covering the same distance down the road? :unsure:
If so, that would explain my engine's consumation.
1982 KZ1100-A2/1170 sleeper 😀
  • RonKZ650
  • RonKZ650's Avatar
06 Aug 2016 19:23
#737673
They were known oil burners even when new. If you add a quart every 2000 miles you are doing great. A worn one will burn a quart every 200 miles.
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Aug 2016 19:32
#737674
That's what I was using before the valve job.
  • jdvorchak
06 Aug 2016 21:25
#737681
Thanks guys. It's just about due for an oil/filter change as I like to do that at about 3k mile intervals. I guess what threw me was that my son does most of the riding and he used what was left of the Rotella I had hanging around. I'm just happy to see that he checks oil level and tire pressure regularly. That got me thinking and so I thought I'd ask here first. That bike has been super reliable but noticing a little slipping clutch in 2nd and 3rd when you get up into the torque range approaching red line. I'm thinking about a new clutch and springs over the winter. Usually clutches last longer than that but I have no idea how it was ridden for the first 28k miles of it's life.
John
83 KZ550M1
83 KZ1100LTD
Also own:
