kz1100 build
- jumbulias
kz1100 build
06 Aug 2016 10:35
What would be the biggest and best for street use. Pistons, Cams, Head Carbs, etc. I have a 82 kz1100 spectre to work with.Any advise appreciated
- missionkz
Re: kz1100 build
06 Aug 2016 11:08
If you mean normal street use, stay pretty much stock.
One thing I noticed, and nobody else really ever talks about, is that when going from my stock 1015 ART pistons to the Wiseco 1075cc pistons, and after getting my jetting dialed in, I still noticed a slight drop in off idle torque takeoff from a dead stop in normal street driving.
I've assumed this was because the mass of revolving parts was lighter with the Wiseco kit and flywheel effect was less pronounced.
That could be illusionary. LOL!
However once up to around 3000-3500rpm and on, the engine felt like it rev'd a bit faster up to 7500-8500rpm
Plus I can ride in 5th gear at a slightly lower speed and RPM then I could with the ART pistons, with decent power to accelerate back up to faster traffic speeds.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- jumbulias
Re: kz1100 build
06 Aug 2016 13:57
I am thinking about the 1135 kit from mtc, and andrews 3x cams, head rebuild with porting . I also have keihin crs33 carbs. I have 2 kz1000ltd ,s and the kz1100 spectre . Cant decide which one i want to build up. Want the build to be for street not drag.
Re: kz1100 build
06 Aug 2016 15:27
A set of good cams will give you more right now. You can always go bigger later.
- jumbulias
Re: kz1100 build
06 Aug 2016 16:43
I thought I would get head redone. Cavanaugh racing . Bigger cams. piston kit. Trying to figure out what combination is best for the kz1000 or the kz1100
Re: kz1100 build
06 Aug 2016 16:45
If you can afford it go for it. :woohoo:
- daveo
Re: kz1100 build
06 Aug 2016 17:49jumbulias wrote: I am thinking about the 1135 kit from mtc, and andrews 3x cams, head rebuild with porting . I also have keihin crs33 carbs. I have 2 kz1000ltd ,s and the kz1100 spectre . Cant decide which one i want to build up. Want the build to be for street not drag.
My adventure started with this:
www.kzrider.com/forum/2-engine/596933-ca...un-this-on-my-engine
1982 KZ1100-A2/1170 sleeper 😀
Re: kz1100 build
06 Aug 2016 18:07jumbulias wrote: I thought I would get head redone. Cavanaugh racing . Bigger cams. piston kit. Trying to figure out what combination is best for the kz1000 or the kz1100
If you are having Larry C do your head work the only answer as to what components to use should come from Larry C.
Larry should be able to tell you what a proven combination for your bike will be from air cleaner thru exhaust and all parts in between
- daveo
Re: kz1100 build
06 Aug 2016 18:55Street Fighter LTD wrote:jumbulias wrote: I thought I would get head redone. Cavanaugh racing . Bigger cams. piston kit. Trying to figure out what combination is best for the kz1000 or the kz1100
Dave![]()
+1 on that!
Given the opportunity to do it over again, I'd pass. As it is, this one (and only) keeps turning out way-better than I ever imagined. If not for the encouragement to experiment from experts on this forum, it would never have started...and I would surely be the poorer for it.
Go for it, and put your trust in these guys!
- jumbulias
Re: kz1100 build
12 Aug 2016 11:59
Hello Dave What size pistons, camshaft do you have on the LTD. Been thinking about a Mr Turbo Kit thanks brett
- Kray-Z
- I need more power Scotty....
Re: kz1100 build
12 Aug 2016 23:54jumbulias wrote: Hello Dave What size pistons, camshaft do you have on the LTD. Been thinking about a Mr Turbo Kit thanks brett
A street turbo air cooled engine? I'd say you might not enjoy that most of the time...
I'd stick to what Larry Cavanaugh recommends when you tell him what kind of riding you do, and how much performance you want..... and how much money you have to spend!
If you are trying to decide between hopping up a '72-'80 Z1/ KZ900/ KZ1000 vs. an 81 and up KZ1100LTD, hands down the 81 and later engines will give more performance potential and bang for the bucks spent. Even better if you can find one - 84 - 85 LTD1100 engines were the best of all the shafties....
