KZ750 Crankcase won't close!
- Saxobass
31 Jul 2016 18:21
Hi all, I'm attempting to close the crankcase on my 1982 KZ750 H3. The front goes together fine but somewhere around the clutch basket area it is getting hung up and will not close all the way. What could be causing this and what can I do about it?
1982 KZ750 H3
-Wiseco 810 kit
-Dyna S pickup
-Dyna coils
-Motogadget M-Unit Blue
-Revival Cycles starter solenoid
-Kz650 Kickstarter
-Progressive fork springs
-Wiseco 810 kit
-Dyna S pickup
-Dyna coils
-Kz650 Kickstarter
Re: KZ750 Crankcase won't close!
31 Jul 2016 18:35
Are the bearing setting rings on the transmission bearings aligning with the grooves in the cases?
31 Jul 2016 19:21
Beat me to it, also the shift forks in the right places?
- Saxobass
31 Jul 2016 19:27 - 31 Jul 2016 19:30
You know, I don't think they are lining up. How can I align them? And what do you mean by the right places Steve?
1982 KZ750 H3
-Wiseco 810 kit
-Dyna S pickup
-Dyna coils
-Kz650 Kickstarter
-Wiseco 810 kit
-Dyna S pickup
-Dyna coils
-Kz650 Kickstarter
Last edit: 31 Jul 2016 19:30 by Saxobass.
31 Jul 2016 20:22
Turn the shift drum to neutral with the large fork fitting the center coller and line up the two small ones where they fit where they're supposed to be.
- Bozo
- Ride it like u stole it
31 Jul 2016 20:32Also, I don't know about the 750, but the KZ1000/900 have dowel pins on some needle bearings as well as the setting rings. the rings should line up when the cases go together by just pushing the shaft either way (assuming all spacers are correct), and the dowels will only line up by turning the bearings dowel line up with the holeSaxobass wrote: You know, I don't think they are lining up. How can I align them? And what do you mean by the right places Steve?
- Saxobass
01 Aug 2016 21:52
Thank you all for your help! It turned out that the dowel pin holes were not aligned with dowels while the rings were pretty well aligned. My crankcase is whole again and thank you once again!
1982 KZ750 H3
-Wiseco 810 kit
-Dyna S pickup
-Dyna coils
-Kz650 Kickstarter
-Wiseco 810 kit
-Dyna S pickup
-Dyna coils
-Kz650 Kickstarter
