shift shaft seal for 550?
- Zaddict
- Enjoying my Zaddiction!
14 Jul 2016 13:37
Anybody know the part number for the shift shaft oil seal for a 550? Or which parts diagram to look at to find it?
Thanks!
Thanks!
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Re: shift shaft seal for 550?
14 Jul 2016 13:44
There are three in all.
- loudhvx
14 Jul 2016 13:46 - 14 Jul 2016 13:51
It's under "breather, oil pan". I'll see if I can find it.
I looked up Kz550D1, though. Not Zr550.
www.kawasaki.com/Parts/PartsDiagram/144584/1981/KZ550-D1
originally with part number prefix 92049B ...
Here's the Zeph:
www.kawasaki.com/Parts/PartsDiagram/31639/1990/ZR550-B1
But now both (Kz/Zr) now use the new number: 92051-005
Here's the Zeph:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 14 Jul 2016 13:51 by loudhvx.
- Zaddict
14 Jul 2016 13:51
Ah good, so it would be 92049B? I'll see if the zr550 part is the same. I know where to look now, thank you.
I see only one seal though, not 3. Maybe the others are internal?
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
14 Jul 2016 13:51
Two on the sprocket cover inside and out. One on the "mission cover."
- loudhvx
14 Jul 2016 13:52 - 14 Jul 2016 13:58
I edited my post with a new link. Both use same part now.
Please double check me, though. I don't want you getting a countershaft seal. Unless you also need that.
The Kz diagram shows 3 seals. The ZR only 2. Doesn't the ZR use a clutch actuator on the clutch cover? That clutch pushrod seal would be eliminated then.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 14 Jul 2016 13:58 by loudhvx.
- loudhvx
14 Jul 2016 13:57
Same deal on the sprocket shaft. Both now use 92050-024.
Please double check in my previous posted links.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Zaddict
15 Jul 2016 09:22
OK, thanks for all the info. Looks like my shaft seal isn't leaking at all when I have the cover plate attached, but as soon as I remove it oil pretty much pours out. Will need to address that soon.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
