- Thank you received: 1616
Shortening Kz550 clutch cable
- loudhvx
14 Jul 2016 09:35 #734919
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Shortening Kz550 clutch cable was created by loudhvx
1981 KZ550 D1 gpz.
Other links.
- loudhvx
14 Jul 2016 09:37 #734920
by loudhvx
1981 KZ550 D1 gpz.
Other links.
Replied by loudhvx on topic Shortening Kz550 clutch cable
1981 KZ550 D1 gpz.
Other links.
- loudhvx
14 Jul 2016 09:39 #734921
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
14 Jul 2016 09:41 #734922
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
14 Jul 2016 09:42 #734923
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
14 Jul 2016 09:44 #734925
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
14 Jul 2016 09:45 #734926
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
14 Jul 2016 09:46 #734927
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
14 Jul 2016 09:48 #734929
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
14 Jul 2016 09:49 - 14 Jul 2016 09:52 #734930
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
Last edit: 14 Jul 2016 09:52 by loudhvx.
- loudhvx
14 Jul 2016 09:53 #734931
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
14 Jul 2016 10:00 - 14 Jul 2016 10:04 #734932
by loudhvx
1981 KZ550 D1 gpz.
Other links.
This diagram is specifically for the 1981 Kz550D1 Gpz. 54011-1025 clutch cable and the aftermarket substitute K28-8062 cable.
Other Kz550's will have different overall length, but the free-length measurement should be the same.
The red dimensions are the important ones when making a new cable.
REMEMBER: The cable must also go through the lever end barrel (about an extra 5/16"), so make sure it is included when you cut!!!! Too long is ok. Too short is a disaster.
Open this image in a new tab to see it clearly.
These measurements are sort of an average from several different cables. Your measurements might vary +/- 1/8" or so.
1981 KZ550 D1 gpz.
Other links.
Last edit: 14 Jul 2016 10:04 by loudhvx.
