Clutch cable problem?
Re: Clutch cable problem?
14 Jul 2016 12:13
Replace the cable. This is what I use for cable lubrication. Quick, easy, and relatively mess-free.
Grrr. Can't load pic from iPad.
14 Jul 2016 13:04 - 20 Feb 2017 19:47
EZ pull ball and ramp. Use axle grease, install as I suggested. I have a O ring chain. I spray chain lube on it every 2-400 miles. A standard chain needs it every 200 or so. Less depending where you are. Cleaning wouldn't hurt the sprocket cover. I use PJ1 chain lube for O ring chains. I've used the chain lube found at the local A/P stores too.
Last edit: 20 Feb 2017 19:47 by SWest. Reason: sp
- MFolks
14 Jul 2016 13:37
Where the cable attaches to the clevis can wear the rivet,causing an unusual feel to the clutch action. Check for wear,as this happen to my 1982 GPz 1100 B2 . I repaired it by drilling out the rivet,and installing a 1/4" bolt,making sure there were no threads to wear away parts.
