removing cap and spring/ changing cam cover gasket
  • eddiem
  • eddiem's Avatar Topic Author
  • KZR FLAG RELAY CARRIER #63
04 Jul 2016 12:13
#733823
read about this on another thread and didn't want to hijack.
kz1100 1982
If you take the cam cover off and not turn the motor over will it be ok to put the cover back on without removing the cap and spring? I just replaced the cam cover gasket and didn't take the cap and spring out.
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • Nessism
  • Nessism's Avatar
Re: removing cap and spring/ changing cam cover gasket
04 Jul 2016 12:39
#733825
eddiem wrote: read about this on another thread and didn't want to hijack.
kz1100 1982
The cap is 17mm hex. Use a socket with extension is it will be off in 10 seconds. Why in the world wouldn't you want to do this?
BTW, once the spring is out be sure to pull back on the wedge to make sure it's not jammed in too tight. After the valve cover is installed just put the spring and cap back on and done. It couldn't be simpler.
The following user(s) said Thank You: eddiem
  • eddiem
04 Jul 2016 12:46
#733826
I didn't realize it needed to be done that way.
I'll take the cover back off and do it like it should have been done.
Thank you
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
