2 into 1 exhaust for my KZ 750 m1 twin
- Captainkiwi
- Vrooooooooom
28 Jun 2016 15:19
Hey guys anyone know where I can get a reasonably price set of 2 into 1 pipes for my KZ 750 m1 CSR
Re: 2 into 1 exhaust for my KZ 750 m1 twin
29 Jun 2016 06:33 - 29 Jun 2016 06:34
Mac sells various exhaust systems for the 750-Twin, but I don't know how good the quality is, such as the fit at the cylinder head ports or how the finish holds up against heat.
eebbaayy search = kz750 exhaust ..... Mac KZ750 Twin 2-1 #802-0703
Last edit: 29 Jun 2016 06:34 by martin_csr.
The following user(s) said Thank You: Captainkiwi
- bountyhunter
29 Jun 2016 14:26I got a used MAC set off ebay for $50 some years back.Captainkiwi wrote: Hey guys anyone know where I can get a reasonably price set of 2 into 1 pipes for my KZ 750 m1 CSR
- KZQ
- Administrator
01 Jul 2016 05:51martin_csr wrote: Mac sells various exhaust systems for the 750-Twin, but I don't know how good the quality is, such as the fit at the cylinder head ports or how the finish holds up against heat.
I purchased a Mac 2 into 1. Had to call them up and ask if it was still available because it didn't show on their website. When I tried to fit it to the heads I found that it wouldn't seal up. I ended up using a large oak dowel shoved into the headpipe to tweak the pipe and bend it enough to make the seal. In the end I learned a good technique about fitting headers. I like the pipe and think it looks good. Don't remember the jetting I settled on but it too wasn't difficult to sort out. I'm running a stock intake.
Regards
Bill
Attachment DSC_0015s.JPG not found
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- bountyhunter
01 Jul 2016 15:49 - 01 Jul 2016 15:57I had to use double gaskets on one side.KZQ wrote:martin_csr wrote: Mac sells various exhaust systems for the 750-Twin, but I don't know how good the quality is, such as the fit at the cylinder head ports or how the finish holds up against heat.
That bike is BEAUTIFUL. It is exactly how mine looked back in 1979 when I bought it except you doubled up on the front disc brakes.
JETTING: I am running th same mac 2-1 with stock airbox and the best jetting was stock main (125) and one up on the pilot (up to 50). The 50 pilot runs best with all the headers I have tried. IMHO, the MAC flows about the same as stock has about the same power but sounds better.
Last edit: 01 Jul 2016 15:57 by bountyhunter.
