82 kz550 ltd
- greene.1993
82 kz550 ltd
20 Jun 2016 18:45
So when I was riding for 15 mins today I notice my engine will make a popping sound when I let off the throttle quick and it well pop when it sits idle when I get home. I checked spark plugs and # 4 #3 #2 seems to be fine in color, not much black on the white insulator but then I take #1 plug out and noticed the insulator is black and the metal on the bottom of spark plug is alil black too, is this a result of #1 cylinder running rich?
Re: 82 kz550 ltd
20 Jun 2016 18:55
Sounds like they're all rich. Valves adjusted?
- greene.1993
Re: 82 kz550 ltd
20 Jun 2016 19:02
Carbs are the last thing to be adjusted.
- greene.1993
Re: 82 kz550 ltd
20 Jun 2016 19:08 - 20 Jun 2016 19:24
Well can't adjust the valves because they have shims and can get to the unless to take the cover off
Last edit: 20 Jun 2016 19:24 by greene.1993.
Re: 82 kz550 ltd
20 Jun 2016 19:12
Do you have a manual?
