Oil change
  • 2_Scott
  • 2_Scott's Avatar Topic Author
Oil change
18 Jun 2016 13:22
#731883
Hi,
I have an '81 KZ550 and I changed the oil and filter. Now, the "Oil" light on my tach won't go off. I think I properly accounted for the extra oil due to the filter change using just under 4 quarts.
Does anyone have any experience with this? The bike seems to be running well and all the oil gets sucks up out of the viewing window when it is running.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Oil change
18 Jun 2016 14:14
#731890
What kind of oil ???
What weight ??
Have you gotten the bike warmed up and ridden it ?
Dave B) B) B)
  • bountyhunter
  • bountyhunter's Avatar
Re: Oil change
18 Jun 2016 17:26 - 18 Jun 2016 17:28
#731916
Have an Ohm meter?
Ohm to ground at the point where the oil sensor wire attaches to the oil pressure sending unit. I think it should read "open" to ground when pressure is up and short when pressure is too low.
Last edit: 18 Jun 2016 17:28 by bountyhunter.
  • missionkz
  • missionkz's Avatar
Re: Oil change
18 Jun 2016 17:26
#731917
2_Scott wrote: Hi,
Make sure you didn't just knock the lead wire and or clip off the oil pressure, sending switch.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
